| Message |
Just got a new set of tires and had alignment checked. old tires had wear on inner edges. Alignment check said it is from a combination of too much negative camber and toe-out. Looking to get 300degree camber kit, but was wondering if upper control arm bushings typically go bad, like most of the other suspension bushings, and if there is a preferred replacement. Haven't seen a listing for ES replacements. Thanks
